Add solar forecast to energy integration
I note that you can only add a solar forecast at the same time as you add a new pv source… If you try to just add a forecast later, the ‘save’ button is not active. I’d consider that a bug.
Work around is to read an existing pv source, then delete the first one.
Please report this issue so it gets fixed:
