Hi, i’ve problems to add sonos zbbridge to HomeAssist
done the guide How to use the Sonoff Zigbee Bridge with Home Assistant - Tasmota
3 times.
first attempt, HA add integration zigbeeHomeAutomation works but found not the Sonoff Mini, so i deleted the integration.
Then i tried to add the integration again, won’t work anymore
Add
sonosSonoff zbbridge to HomeAssist - unknown error occuredHi, i’ve problems to add
Hey @RKsHAss,
at the level on which you described your issue it’s not easy to help you resolve the issue.
As a ZBBridge user myself, I can tell you that it works flawlessly (Edit: in the small setup I utilize it in. Generally I’d also recommend a wired device for a bigger setup, as @Hedda said). Not sure how accurate your article is but I’d suggest to follow the main article at Sonoff Zigbee Bridge (ZBBridge) Zigbee compatibility to prepare your device with the latest Tasmota firmware, then configure it in Home Assistant using the instructions for “ZHA” at the bottom of the article.
Also see https://community.home-assistant.io/t/sonoff-zbbridge-sonoff-zigbee-bridge-from-itead/187346
Note! Because it uses WiFi it is not recommended to use Sonoff ZBBridge with ZHA or Zigbee2MQTT:
I’m not using Wifi.
And yes i followed that documentation
And it works the first time - adding the sonos zbbridge to HomeAssist
But after deleting the sonos zbbridge integration i can not add it again
After several reboots and at least pull the power and restart again it works
What do you mean by “not using Wifi”? You can not use ITead’s ZBBridge Zigbee Bridge without Wi-Fi.
Regardless, no one will be able to help you more unless you actively volunteer way better descriptions.
PS: The brand is named “Sonoff”, not “Sonos” which is a brand for completely different type of devices.
Sonos doesn’t make a product called Zbbridge. It’s Sonoff (Itead, to be specific). Please take a moment to correct your posts. Otherwise, when users search for topics related to Sonoff Zbbridge, your topic might not appear in the search results.
