Add spotlight support for Reolink cameras
Some Reolink cameras support spotlights, such as the Duo 2, the Argus 3 and so on.
The upstream library the HA Reolink integration uses supports turning on the spotlight and setting the brightness, so it’d be nice if the integration would expose a light entity that you could use to turn the spotlight on and off via the dashboard or in automations.
The library also supports stuff like turning the alarm on, setting the IR (night vision) lights, so having those available as options would be useful too.
This is now available in the latest HomeAssistant release in the build-in reolink integration.
If you appreciate the reolink integration and want to support its development, please consider sponsering the upstream library or purchase Reolink products through this affiliate link.
