Hi!
First time posting anything here so I hope I’ve found the right place.
The problem:
CalDAV integration can not pull subscription calendars from Nextcloud. The integration is only able to show your personal calendars.
Since Nextcloud seems to be a well used platform in the community, I can’t be the only one missing this feature =)
My family only uses Nextcloud calendars and being able to get all subscriptions from schools and other communities directly into HA would be a super smooth addition to everyones daily life.
I fully support adding this feature. I am just getting into using Nextcloud calendars, and naturally getting them setup through HA. I am a bit surprised this feature isn’t possible.
Yeah, I followed your posts on the nextcloud help and github and I see that it’s not as simple as it maybe sounds like it should be. It would be nice to just manage calendars from a self hosted solution. The nextcloud HA integration is basically useless as it is to me. I don’t need a sensor on the number of files. But supporting every possible app through the integration would be cumbersome.
To be honest, I wasn’t even aware they had introduced a nextcloud integration
But as you said, counting files is not very useful. Maybe for monitoring suspicious activity, but not much else.
Haven’t had a look at my post at nextcloud for quite some time, but I suspect not much has happened.
