Add support for charging stations to the Growatt integration
Currently Growatt - Home Assistant only support solar inverters. Growatt also produces EV charging stations wallnoxes like Growatt Thor THOR 11/22AS-S/P | AC EV-lader | Growatt
Api documentation is available here: Growatt Charger Open Api
Would be nice to control charging from home asistant
Is there a way to cotrol the wallbox?
There is, using OCPP.
Using AP mode it’s possible to change the OCPP server and then connect it to HASS
