Add support for Cloudflare Access to trusted_networks auth provider
I use Cloudflare Access as an authenticated reverse proxy for my Home Assistant instance, and to simplify my login flow I’ve whitelisted Cloudflare’s IP ranges using the trusted_networks authorization provider as shown below:
homeassistant:
  auth_providers:
    - type: trusted_networks
      trusted_networks:
        - 192.168.0.0/16
        - 103.21.244.0/22
        - 103.22.200.0/22
        - 103.31.4.0/22
        - 104.16.0.0/12
        - 108.162.192.0/18
        - 131.0.72.0/22
        - 141.101.64.0/18
        - 162.158.0.0/15
        - 172.64.0.0/13
        - 173.245.48.0/20
        - 188.114.96.0/20
        - 190.93.240.0/20
        - 197.234.240.0/22
        - 198.41.128.0/17
      allow_bypass_login: true
In order to make things simpler for other users, and to make this setup more resilient to changes on Cloudflare’s side, I’d like to add a boolean cloudflare_access configuration parameter to trusted_networks that would transparently fetch the latest IP list from Cloudflare and add them to the whitelist.
I had originally considered creating a separate authorization provider to handle this, but as it would be a near duplicate of trusted_networks, it seems like a better solution would be to simply add this functionality to the existing module.
@balloob, I’d be interested to hear your thoughts on this.
It’s taken me an age to figure out my issues with x-forwarded-by and Cloudflare … it seems to me that an opt-in of trusted networks providers would be extremely useful.
For me, this post was extremely useful.
Nice, glad I could help!
If anyone comes here for answers … I have a cloudflare -> nginx proxy -> HA on TrueNas …
Adding the CloudFlare networks corrected the entire x-forwarded-by … otherwise I just received “Login attempt or request with invalid authentication from 162.158.165.218 (162.158.165.218). See the log for details.” Which was of no use.
HA needs a log of invalid authentication.
doesn’t this mean anyone on a cloudflare IP address as specified gets straight in with no authentication?
Cloudflare Access is an identity-aware that provides the authentication. From Cloudflare:
To secure your origin, you must also enable Argo Tunnel or limit connections to your origin to allow only Cloudflare IPs and verify the JWT.
FWIW, CloudFlare included their Tunnels feature in the free tier: https://blog.cloudflare.com/tunnel-for-everyone/ So you can set up a tunnel to CloudFlare and not allow any inboud traffic to your server.
Thanks, I didn’t know about this!
Did anyone has had success with the cloudflared plugin?
Yes, it works well. Followed instructions, added the add-on, configured a remote tunnel - done. I already had Cloudflare DNS setup, so that helped.
Yes so mine works as well, but I wasn’t able to get the authentication up and running :frowning:
(basically I have two logins now)
