Add Support for Fujitsu wireless Air Conditioning control app - FGLair
Does anyone have any tips getting this working with the thermostat card in lovelace? At this stage its missing all of the standard thermostat card capabilities other than adjusting the temperature. I have started building a bunch of toggles etc, but thought I should also ask if anyone knew how to get it working as that’s all I am after.
I found that eu-central-1.amazonaws.com is probably used in Europe for FGLair, however I dont know how to alter the pyfujitsu\api.js to make it work…
Anyone know?
Does anyone have the lovelace standard thermostat card working with this addon?
Hey Everyone, first big thanks to Mmodarre for his work on this integration! I just had a Fuji mini split installed and once I figured out the changes in custom_components in Hassio .88, I can see my Fuji minisplit in Hassio.
I am seeing a strange issue. Although I can see and set the temp of the Fuji minisplit from Hassio, the temp will always revert back to its previous temp (what it was before i changed it with Hassio). This happens with no interaction from me. I thought that the IR remote control might be contibuting to this issue, so i pulled the batteries from it. However, the issue still persists. I wonder if anyone has noticed this?
Thanks!
Mine works fine, how long does it take to change back? Does HA show it’s changed back?
Sometimes immediately. Other times up to a minute or so. When I change the temp in Hassio I can see it change in the FGlair app. But then, unexpectedly it will return to the original temp. Hassio and FGLair both show it changed back.
after I upgraded to hassio 0.89. This became broken. Anyone know what happen?
There were changes that are referenced in other threads. I’ve turned mine off for the time being. I plan on looking at it as this seems dead from creators point of view, but it’s going to take me while. As an example this conversation appears relevant: 0.89 Breaking Change: Prevent partial custom component overlays
After upgrading to .88 of HA I had to have directory structure: /config/custom_components/fujitsu_general_heatpump/climate.py (where climate.py = fujitsu_general_heatpump.py)
I got this error after I changed the file name and location
Error loading custom_components.fujitsu_general_heatpump.climate. Make sure all dependencies are installed
Yes I have the same issue. It would seem the changes I referenced in the other thread have broken this - so it doesn’t work in 0.89. It would appear that there might only be minor changes required to get it working again, however I don’t have the python skills at this stage.
@Mmodarre, is there any chance you can update the Python code to resolve the changes to custom components introduced in 0.88?
He has said he will look at it on his GitHub repo when I created an issue
After you have changed the directory structure, modify climate.py (old fujitsu_general_heatpump.py) and remove lines (near the top):
from homeassistant.components.climate import (
    PLATFORM_SCHEMA, SUPPORT_FAN_MODE,
    SUPPORT_OPERATION_MODE, SUPPORT_SWING_MODE, SUPPORT_TARGET_TEMPERATURE, SUPPORT_ON_OFF,
    ClimateDevice, SUPPORT_AUX_HEAT)
Then add the following where you removed the above lines:
    PLATFORM_SCHEMA,
    ClimateDevice
from homeassistant.components.climate.const import (
    SUPPORT_FAN_MODE,
    SUPPORT_SWING_MODE,
    SUPPORT_ON_OFF,
    SUPPORT_AUX_HEAT
Restart Home Assistant…
That worked! Thanks!
Worked like a charm.
Thanks!
Glad it worked!
I upgraded HA just after midnight, and had to fix my heatpump integration before my wife and kids woke up…so I had motivation
Did you solve the european server issue,
i’m installing a similar unit in Malta europe and wanted to know if this can be integrated.
thanks
Not sure if this helps but I decompiled the APK and there are different secrets, app ids and urls based on region - which is why you would be having issues in EU. These are set on https://github.com/Mmodarre/pyfujitsu/blob/master/pyfujitsu/api.py
Secrets:
EU
"FGLair-eu-gpFbVBRoiJ8E3QWJ-QRULLL3j3U"
US
"CJIOSP-Vb8MQL_lFiYQ7DKjN0eCFXznKZE"
CH
"FGLairField-cn-zezg7Y60YpAvy3HPwxvWLnd4Oh4"
App Ids:
EU
"FGLair-eu-id"
US
"CJIOSP-id"
CH
"FGLairField-cn-id"
Urls change too:
would be
API_BASE_URL = "https://ads-eu.aylanetworks.com/apiv1/"
API_GET_ACCESS_TOKEN_URL = "https://user-field.aylanetworks.com/users/sign_in.json"
would be
API_GET_ACCESS_TOKEN_URL = "https://user-field-eu.aylanetworks.com/users/sign_in.json"
I don’t have access to another region one so can’t help more than the above but hopefully that helps someone.
China domains are (in case anyone ever wants it)
"https://ads-field.ayla.com.cn/"
"https://user-field.ayla.com.cn/"
Sweet! Thank you so much! I got it working!!
The server info worked once I found that I had to edit the correct api.py file.
This: c:\Users\OleAndor\AppData\Roaming.homeassistant\deps\Python36\site-packages\pyfujitsu
Not this: c:\Windows\SysWOW64\homeassistant\Lib\site-packages\pyfujitsu\
I also had to tweak the climate.py in:
c:\Users\OleAndor\appdata\Roaming.homeassistant\custom_components\fujitsu_general_heatpump'
Since I got a lot of errors. For now I just commented out some code.
Typical error:
File “C:\Users\OleAndor\AppData\Local\Programs\Python\Python36\lib\site-packages\homeassistant\helpers\service.py”, line 291, in handle_service_platform_call
await func(entity, data)
File "C:\Users\OleAndor\AppData\Local\Programs\Python\Python36\lib\site-packages\homeassistant\components\climate_init
.py", line 556, in async_service_aux_heat
await entity.async_turn_aux_heat_on()
File “C:\Users\OleAndor\AppData\Local\Programs\Python\Python36\lib\site-packages\homeassistant\components\climate_init_.py”, line 482, in async_turn_aux_heat_on
return self.hass.async_add_job(self.turn_aux_heat_on)
File “C:\Users\OleAndor\AppData\Roaming.homeassistant\custom_components\fujitsu_general_heatpump\climate.py”, line 177, in turn_aux_heat_on
self._fujitsu_device.powerfull_mode_on()
File “C:\Users\OleAndor\AppData\Roaming.homeassistant\deps\Python36\site-packages\pyfujitsu\splitAC.py”, line 69, in powerfull_mode_on
self.powerful_mode = 1
File “C:\Users\OleAndor\AppData\Roaming.homeassistant\deps\Python36\site-packages\pyfujitsu\splitAC.py”, line 233, in powerful_mode
self._api._set_device_property(self.powerful_mode[‘key’],properties)
TypeError: ‘NoneType’ object is not subscriptable
