Add support for Hue effects
Every Hue bulb has an effect variable that can be set to either none or colorloop. Could you please add support for it?
This is already supported, have a look here.
I’ve tried both colorloop and random with my Hue setup (bulps and lightstrip), and I can confirm they work.
Can you access that from the HASS frontend?
You could, either by:
  • making a script and adding it to the HASS frontend
  • adding an input_boolan to the HASS frontend, which serves as a trigger for an automation that turns on the desired lights with the random effect
Here’s a script I use as an example:
office_moodlight:
  sequence:
    - service: light.turn_on
        entity_id: light.lightstrip_desk
        effect: random
        brightness: 127
        transition: 5
I use this script as an action in an automation, but you could just add it to the HASS frontend. It will then show an “ACTIVATE” link.
