Please add support for Nedis Zigbee devices within the Tuya integration. I have them in the Tuya Smart app, connecting via a Nedis Zigbee gateway - WIFIZB10CWT. The Tuya integration gives the following diagnostics:
Nedis Zigbee motion sensor - ZBSM10WT:
"documentation": "https://www.home-assistant.io/integrations/tuya",
"integration_type": "hub",
"iot_class": "cloud_push",
"loggers": [
"tuya_iot"
"requirements": [
"tuya-iot-py-sdk==0.6.6"
"is_built_in": true
"data": {
"endpoint": "https://openapi.tuyaeu.com",
"auth_type": 0,
"country_code": "**",
"app_type": "tuyaSmart",
"mqtt_connected": true,
"disabled_by": null,
"disabled_polling": false,
"name": "living room motion",
"model": "ZBSM10WT",
"category": "pir",
"product_id": "bd5faf9p",
"product_name": "Motion sensor",
"online": true,
"sub": true,
"time_zone": "+02:00",
"active_time": "2023-09-07T13:16:42+00:00",
"create_time": "2022-03-19T08:58:46+00:00",
"update_time": "2023-09-07T14:45:20+00:00",
"function": {},
"status_range": {
"PIR": {
"type": "Boolean",
"value": {}
"battery": {
"type": "Integer",
"value": {
"unit": "",
"min": 0,
"max": 100,
"scale": 0,
"step": 1
"status": {
"PIR": false,
"battery": 96
"home_assistant": {
"name_by_user": null,
"disabled": false,
"entities": []
Nedis Zigbee door/window sensor - ZBSD10WT:
"loggers": [
"tuya_iot"
"requirements": [
"is_built_in": true
"data": {
"auth_type": 0,
"name": "storage",
"model": "ZBSD10WT",
"category": "mcs",
"product_id": "crr8qb0p",
"product_name": "Door/Window Sensor",
"online": true,
"sub": true,
"active_time": "2023-09-07T17:09:30+00:00",
"create_time": "2022-03-13T11:40:55+00:00",
"update_time": "2023-09-07T17:09:30+00:00",
"function": {},
"status_range": {
"prm_switch": {
"type": "Boolean",
"value": {}
"Battery": {
"type": "Integer",
"value": {
"unit": "",
"min": 0,
"max": 220,
"scale": 0,
"step": 1
"status": {
"prm_switch": false,
"Battery": 53
"home_assistant": {
"name": "storage",
"disabled": false,
"entities": []
Thanks a million if possible!
