Add support for Smartmi Evaporative Humidifier 3 (zhimi.humidifier.ca6) support to xiaomi_miio
HA and python-miio currently support Smartmi Evaporative Humidifier 2 (zhimi.humidifer.ca4).
Please add support for Smartmi Evaporative Humidifier 3 (zhimi.humidifier.ca6). It is similar to ca4. It even works if one manually specifies the ca4 model in the configation. But there substantial differences:
  • Modes are different, i.e. there are three modes: Fav (aka Max), Auto, Sleep.
  • Water level meaning is different, i.e. 0 - min/empty, 1 - normal, 2 - max/full.
  • Target humidity max level is 60%, instead of 80%.
Here are ca6 specs:
I have already submitted issue to python-miio (Add support for Smartmi Evaporative Humidifier 3 (zhimi.humidifier.ca6) support to xiaomi_miio · Issue #1884 · rytilahti/python-miio · GitHub).
I have implemented initial support of zhimi.humidifier.ca6.
  • PR to python-miio is here
  • home-assistant/core branch is here
I will work now to make these available upstream.
Here are a few screenshots:
Great! Is it possible to determine if this PR is part of a Home Assistant release?
EDIT: By looking in the github platform I mean
@smoroz Any news on that when that will be available in HomeAssistant?
My PR to python-miio has been recently merged into master. Now we need to wait for the official release of a new version of python-miio library. And after that I will do PR in home-assistant, because I can’t add dependency to dev version of the library :frowning:
Awesome work man, thanks. I have been looking into getting the evaporative 3 and I just saw that it is not yet included in the miio integration. It seems python-miio only just (mar 13) had its first release in almost 2 years. Think it could be anytime soon that we could get this device supported or am I better off buying the evaporative 2?
Hey @smoroz, do we have any progress on making it into HA?
Can anyone confirm the V3 is supported in the latest HA release? We have a V2 and would like another one for a different room and the V3 looks to be a bit better as long as it will work with HA :wink:
Still not supported in official release :frowning:
You can use GitHub - al-one/hass-xiaomi-miot: Automatic integrate all Xiaomi devices to HomeAssistant via miot-spec, support Wi-Fi, BLE, ZigBee devices. 小米米家智能家居设备接入Hass集成 to get support for Smartmi Evaporative Humidifier 3
Hello, So, how cham i add smartmi humidifier do Home Assistant? What should i use?
as said in the OP add it through xiaomi mii as ca4.
though you dont get all the functionality until the ca6 gets added to core
I found that it is already in master branch for miio repository. Can you create a PR for HA core?
Hello, would you mind opening a PR to HA/core once your implementation is ready?
Any chance for adding zhimi.humidifier.ca7 as well?
This is Smartmi Evaporative Humidifer 3 Lite.
