Add Support for Temp and Humidity Sensor ID: yjjdcqsq
Purchased this Temp sensor off Amazon, works fine in Tuya app, but HA says “unsupported” despite all the data being there in the Diag
"is_built_in": false
  "data": {
    "endpoint": "https://apigw.tuyaus.com",
    "terminal_id": "1707569849542FtVsuW",
    "mqtt_connected": true,
    "disabled_by": null,
    "disabled_polling": false,
    "id": "eb5fb1bc6ea2b479666xkr",
    "name": "T & H Sensor",
    "category": "wsdcg",
    "product_id": "yjjdcqsq",
    "product_name": "T & H Sensor",
    "online": true,
    "sub": true,
    "time_zone": "+00:00",
    "active_time": "2024-03-01T15:26:58+00:00",
    "create_time": "2024-03-01T15:26:58+00:00",
    "update_time": "2024-03-01T15:26:58+00:00",
    "function": {
      "temp_unit_convert": {
        "type": "Enum",
        "value": {
          "range": [
            "c",
            "f"
    "status_range": {
      "va_temperature": {
        "type": "Integer",
        "value": {
          "unit": "\u2103",
          "min": -200,
          "max": 600,
          "scale": 1,
          "step": 1
      "va_humidity": {
        "type": "Integer",
        "value": {
          "unit": "%",
          "min": 0,
          "max": 100,
          "scale": 0,
          "step": 1
      "battery_state": {
        "type": "Enum",
        "value": {
          "range": [
            "low",
            "middle",
            "high"
        "type": "Enum",
        "value": {
          "range": [
            "c",
            "f"
    "status": {
      "va_temperature": 197,
      "va_humidity": 38,
      "battery_state": "high",
      "temp_unit_convert": "c"
    "home_assistant": {
      "name_by_user": null,
      "disabled": false,
      "entities": []
    "set_up": false,
    "support_local": true
