Add support for Tesla Powerwall
If you want to try the more complicated way, here is my write up of the steps that I followed:
If you want to use the method you started then here: Add support for Tesla Powerwall - #309 by markpurcell
This integration and the automations people have shared above are awesome. Thank you all!
Iā€™ve created an automation to decide whether to charge from the grid, based on predicted solar generation for the next day. Iā€™m trying to figure out the best combination of actions when switching to grid charging, for example whether to leave in self-powered mode and alter the backup reserve percentage, or instead to switch to time-based mode, which will also make grid charging kick in during my off-peak time.
Iā€™ve read in a few places that the charging rate is limited in self-powered mode. If I switch to time-based control, I guess it has a target charge time to aim for (i.e. the end of the off-peak time) so it ramps up more to reach that target. The benefit to this would be a quicker charge time and therefore less overall time in grid-charging mode (with other appliances also drawing from the grid and therefore slightly higher cost).
Can anyone whoā€™s tested this spare me a very late night and confirm whether thatā€™s the case? I have a Powerwall 2 in case that matters.
This feature request is now well supported by the custom integration:
For me the different modes do charge at different rates, it also depends on the size of your solar as well as I think the powerwall uses that to calculate how much energy will be supplied during the day.
The rough rule of thumb I have seen is:
Setting the backup reserve higher will charge at about 33%, i.e. ~ 1.7kW.
Setting the powerwall into ā€˜backupā€™ mode (available in the home assistant integration will charge at about 66% ~ 3.4 kW
Setting the time based control during an off peak window will charge upto 100% ~ 5 kW.
Thanks, sadly I didnā€™t see your response last night, but at least I managed to confirm for myself the hard way :laughing:
Youā€™re exactly right, playing with the backup reserve % results in a charge rate of 1.7kW. The only way to get 5kW is to use time-based mode in the off-peak window.
However, Iā€™ve noticed that if you switch to time-based mode after the start of your configured off-peak time window has passed, (e.g. off-peak starts at 23:30 and you only switch to time-based at 23:45), it doesnā€™t seem to kick in at all and start charging. This is annoying as I was planning on delaying the start time depending on how much charging was needed.
Not the end of the world though, it will just start charging at a target time instead of finishing at a target time.
Hi there,
Does anyone know if you can control the switching of grid charging from HA using this integration or another method?
With Spring coming up I can see that there maybe nights when I want to turn off grid charging for that night preceding a high solar day, but others nights still want to switch back to grid charging. I would like to do this by automation based on my Solcast forecast.
The Tesla Custom Integration has the same controls as the Tesla App, so yes you can automate.
Thanx Mark,
got it automated with this:
service: select.select_option
  option: "No"
  entity_id: select.home_energy_gateway_grid_charging
Apologies if this has been answered elsewhere, however I have got so far but have come up against a brick wall!!
Iā€™m trying to set both the operation mode and backup reserve through an automation.
The first action works as expected e.g.
  option: Self-Powered
  entity_id: select.home_energy_gateway_operation_mode
However the second action does not work, in this case trying to set the backup reserve to 5%.
  option: "5"
  entity_id: number.home_energy_gateway_backup_reserve
Any help would be appreciated.
try this in the Automation ACTION:
service: number.set_value
  value: "5"
as its a number then it is a ā€œVALUEā€ and not an ā€œOPTIONā€
Chris, many thanks for the help, worked a treat, much appreciated, Andrew
Hi
I am trying to install manually. I have downloaded the latest from GitHub and copied to custom components.
I get the error ā€œ504 gateway time-outā€ when I click to add the integration.
Any idea what could be causing this?
I just updated to the latest version of the Integrity but on a restart I get the below Error in my logs:
Logger: homeassistant.util.package
Source: util/package.py:98
First occurred: 12:17:21 (3 occurrences)
Last logged: 12:17:39
Unable to install package teslajsonpy==3.7.4: ERROR: Cannot install teslajsonpy==3.7.4 because these package versions have conflicting dependencies. ERROR: ResolutionImpossible: for help visit https://pip.pypa.io/en/latest/topics/dependency-resolution/#dealing-with-dependency-conflicts [notice] A new release of pip available: 22.2.1 -> 23.0.1 [notice] To update, run: pip install --upgrade pip
Im still on the previous versions of HA:
Home Assistant 2022.11.5
Supervisor 2022.11.2
Operating System 9.3
Frontend 20221108.0 - latest
I use teslapy to be able to set my PW in to ā€œautonomousā€ mode which I thought allows the highest charging ratesā€¦however I never seen my PW charge more that 3.6kWh. I read in this thread that it should allow charging at 5kWh can anyone confirm this and if there a setting in the direct battery login menu that limits the maximum charging rate?
Thanx.
I thought it might be nice if we share some of our favourite automatons that others can use. Here one thatā€™s working really well for me. I have my battery reserve set to 35% each morning after charging from grid. But then if itā€™s a low solar day you can get down to 35% and then whatā€¦so here is my automation that starts reducing the reserve setting by 5% when the SOC gets to 3% of the set reserveā€¦I.e. It reduces the reserve all the way to 0% rather than keeping a reserve and having to use the grid.
alias: "POWERWALL: Reduce reserve percentage by 5 % "
description: Or when Powerwall charge SOC drops below 35% during day or night
  - platform: numeric_state
    entity_id: sensor.powerwall_charge_corrected
    below: 38
    below: 33
    below: 28
    below: 23
    below: 18
    below: 13
    below: 8
condition:
  - condition: numeric_state
    above: 0
  - service: number.set_value
      value: "{{states('number.home_energy_gateway_backup_reserve') | float(0) - 5}}"
mode: single
Great idea to share automations.
Practically what is the difference with your automation to just setting your backup reserve to 0% in the first place?
:joy: maybe none!
But I always thought of it as good to have a backup reserve but you are right, Iā€™m effectively overriding that.
I love this thread and have read through it many times. My powerwall was installed last week and I have written automations to change the mode to Time-Based Control and reserve value when my electricity is cheap and I have calculated that I need to charge from the grid. After my 4 hours of cheap electriciy I change the mode back to Self-Powered and reserve back to 10%. Iā€™ve also set up a boolean helper that changes to ā€˜onā€™ when I run the first automation. Iā€™m stuck a bit now on how to revert to Self-Powered and 10% reserve when the Powerwall charge is greater than my set point. Something like IF input_boolean.solar_powerwall_charging = on AND sensor.powerwall_battery_now > input_number.solar_powerwall_reserve_setpoint THEN change mode to Self-Powered and reseve to 10%. Probably missing the obvious but Iā€™ll ask anway.
alias: Powerwall Stop Charging
description: Stop the Powerwall charging when it reaches the set point
    entity_id: sensor.powerwall_charge_3
    above: input_number.solar_powerwall_reserve_setpoint
condition:
  - condition: state
    entity_id: input_boolean.solar_powerwall_charging
    state: "on"
  - service: input_boolean.turn_off
    data: {}
  - service: select.select_option
      entity_id: select.my_home_operation_mode
      entity_id: number.my_home_backup_reserve
      value: "{{ 10 }}"
mode: single
Here is something similar that I use. I have my powerwall set point called ā€œovernight_powerwall_max_chargeā€ and I also have a EV and Myenergi got water heater (EDDI) so when either of they are ON I just want to stop the PW from further charging but donā€™t want the PW to discharge in to the EV or heat the hot water. So there are some choices that the automation makes to prevent thatā€¦
alias: "POWERWALL: Stop grid charging when SOC > Max overnight charge"
description: ""
    above: input_number.overnight_powerwall_max_charge
  - platform: state
    entity_id:
      - binary_sensor.powerwall_charging
    to: "off"
  - platform: time_pattern
    minutes: /20
    value_template: |-
      platform: template
      value_template: >-
        {{ states('sensor.powerwall_charge_corrected') | float(0) >
states('input_number.overnight_powerwall_max_charge') | float(0) + 9 }}
condition:
  - condition: time
    after: "00:30:00"
    before: "04:30:00"
  - condition: template
    value_template: >-
  - choose:
      - conditions:
          - condition: not
            conditions:
              - condition: state
                entity_id: binary_sensor.ix_xdrive40_charging_status
                state: "on"
              - condition: state
                entity_id: input_boolean.eddi_boosting
                state: "on"
            enabled: true
        sequence:
              option: "No"
              value: "0"
      - conditions:
          - condition: or
            conditions:
              - condition: state
                state: "on"
              - condition: state
                state: "on"
        sequence:
              option: "No"
              option: Backup
              value: "100"
    default:
      - condition: not
        conditions:
          - condition: state
            state: "No"
        enabled: true
      - condition: not
        conditions:
          - condition: state
            state: "on"
          - condition: state
            state: "on"
        enabled: true
          option: "No"
          entity_id:
            - select.home_energy_gateway_grid_charging
        enabled: true
        enabled: true
          value: "0"
        enabled: true
trace:
  stored_traces: 48
mode: single
Very helpful, TYVM.
