Tuneblade transmits the audio rendered on the host machine running tuneblade to one or more airplay devices with audio 100% in sync.
Ideal for multi room audio.
eg. playing back spotify on the tuneblade machine would have the spotify audio rendered on multiple airport endpoints. A good client would be a rpi running shairport-sync.
The API would make it possible to enable/disable rendering to airplay clients as well as controlling their individual volume.
Hi @gibman ,
I’ve created a custom component for this. If you are still interested I can share it.
It’s not the most elegant solution but works well for me.
here a message from the last update of Home Assistant core
2022-01-09 15:58:27 WARNING (MainThread) [homeassistant.helpers.frame] Detected integration that called async_timeout.timeout with loop keyword argument. The loop keyword argument is deprecated and calls will fail after Home Assistant 2022.2. Please report issue to the custom component author for tune_blade using this method at custom_components/tune_blade/media_player.py, line 172: with async_timeout.timeout(TIMEOUT, loop=self.hass.loop):
Hey, thank you for the answer. I installed through HACS but I can’t find the TuneBlade integration and I can’t declare manually in the configuration.yaml
Can you please help me?
Yeah it doesn’t support config via yaml, you need to use the add integration option in Devices and Services. Should appear as long as you have restarted since adding from HACS
hello, i spent about a week working on this project. Unfortunately the hacs add-ons didn’t work for me. So I designed a simple code that works with automation to control tuneblade in http request directly on the target machine with their api.
it is possible to reduce the code a little, because I use sensors which convert the value into % of the volume (it just removes the % in reality) but I will use it for something else later.
I can explain how it works for those who are interested, but the advantage is that it doesn’t require any particular update. here is :
Configuration.yaml:
#Activation switch for connecting airplay devices to the tuneblade server
switch:
- platform: command_line
switches:
connect_airplay_receiver_man_cave_kazador_noir:
command_on: "curl -X GET http://192.168.1.199:6666/v2/123456789/Status/Connect"
command_off: "curl -X GET http://192.168.1.199:6666/v2/123456789/Status/Disconnect"
# Shell command for sending http command to tuneblade server
shell_command:
volume_man_cave_kazador_noir: "curl -X GET http://192.168.1.199:6666/v2/123456789/Volume/{{ states.sensor.volume_man_cave_kazador_noir_value.state }}"
#Airplay device volume control button
input_number:
name: Volume Man Cave Kazador Noir
min: 0
max: 100
step: 1
unit_of_measurement: "%"
initial: 50
icon: mdi:volume-high
Automation.yaml
#Automation for triggering input_number value change and sending value in http for volume control
- alias: "Control volume"
platform: state
entity_id: input_number.volume_man_cave_kazador_noir
service: shell_command.volume_man_cave_kazador_noir
explanation :
-the ip address of your machine hosting your tuneblade (here 192.168.1.199)
-The port directly configure in tuneblade for the remote control (here 6666)
The ID of your target device (here a homepod mini 123456789)
There is no particular design made for the moment on this code, but it allows to connect a specific airplay device, and to control the volume.
An automation allows you to control several devices in this way and synchronize their connection according to what you want.
On your lovelace dashboard, for this example you will need this code to have the corresponding buttons:
