Please add support for the Tuya breaker with electricity meter SMT006 (category dlq).
Here is the reference Add Tuya sensors for Breaker with Electricity Meter (category dlq) by slydiman · Pull Request #58200 · home-assistant/core · GitHub
please add support for a other tuya breaker:
“category”: “dlq”,
“category_name”: “Switch Module”,
“model”: “ZC01W”,
“product_name”: “breaker”,
Thx team
Have installed a smart breaker that looks physically similar to the SMT006 here: https://www.aliexpress.com/i/1005002505542131.html
This is mine:
[EARU Electric Wifi Smart Circuit Breaker - IoT Smart Techs](EARU Smart Breaker with Leakage Detection)
The device can be added using the standard Tuya integration but it’s only reporting the switch, Current(A), Voltage(V), Active Power(kW) values and not showing the Leakage Value (mA). It’s also possible to change the over/under voltage settings, the Leakage threshold before trip and disable/enable the leakage trip setting (RCD function) via the app, but these are also not exposed.
"result": {
"active_time": 1666792802,
"category": "dlq",
"category_name": "Switch Module",
"create_time": 1666784058,
"gateway_id": "",
"icon": "smart/icon/bay1591839287906taVN/073f2e2ff5f3c3c3b62c096c74145863.png",
"id": "bf2624e25637c6axxxxxxx",
"ip": "x.x.x.x",
"lat": "",
"local_key": "local_key",
"lon": "",
"model": "",
"name": "Garden Lights Breaker",
"online": true,
"owner_id": "69235xxx",
"product_id": "r9kg2g1uhhyicycb",
"product_name": "Breaker ",
"sub": false,
"time_zone": "+08:00",
"update_time": 1666792802,
"uuid": "490c456b2xxxxxx"
I have a TO-Q-SY1JWT
Its listed in the Tuya integration.
But only switch and child lock.
The power, voltage, current etc arent there. But if you download the diagnostic data, you can see the variables listed. But no entity.
“data”: {
“endpoint”: “https://openapi.tuyaeu.com”,
“auth_type”: 0,
“country_code”: “44”,
“app_type”: “tuyaSmart”,
“mqtt_connected”: true,
“disabled_by”: null,
“disabled_polling”: false,
“name”: “WiFi Din Rail Switch with metering”,
“model”: “AT-Q-SY1-JWT”,
“category”: “dlq”,
“product_id”: “jdj6ccklup7btq3a”,
“product_name”: “WiFi Din Rail Switch with metering”,
“online”: true,
“sub”: false,
“time_zone”: “+00:00”,
“active_time”: “2022-11-05T18:20:37+00:00”,
“create_time”: “2022-11-05T18:20:38+00:00”,
“update_time”: “2022-11-05T18:20:42+00:00”,
“function”: {
“switch”: {
“type”: “Boolean”,
“value”: {}
“countdown_1”: {
“type”: “Integer”,
“value”: {
“unit”: “s”,
“min”: 0,
“max”: 86400,
“scale”: 0,
“step”: 1
“relay_status”: {
“type”: “Enum”,
“value”: {
“range”: [
“power_off”,
“power_on”,
“last”
“light_mode”: {
“type”: “Enum”,
“value”: {
“range”: [
“relay”,
“pos”,
“none”,
“on”
“status_range”: {
“switch”: {
“type”: “Boolean”,
“value”: {}
“countdown_1”: {
“type”: “Integer”,
“value”: {
“unit”: “s”,
“min”: 0,
“max”: 86400,
“scale”: 0,
“step”: 1
“add_ele”: {
“type”: “Integer”,
“value”: {
“min”: 0,
“max”: 50000,
“scale”: 3,
“step”: 100
“cur_current”: {
“type”: “Integer”,
“value”: {
“unit”: “mA”,
“min”: 0,
“max”: 100000,
“scale”: 0,
“step”: 1
“cur_power”: {
“type”: “Integer”,
“value”: {
“unit”: “W”,
“min”: 0,
“max”: 99999,
“scale”: 1,
“step”: 1
“cur_voltage”: {
“type”: “Integer”,
“value”: {
“unit”: “V”,
“min”: 0,
“max”: 5000,
“scale”: 1,
“step”: 1’
I also bought the EARU Circuit Breaker EAYCBM-T-2P-ZG-25A (Zigbee). I addetit to Home Assistant, but no controls are available.
Any suggestion on what could I do?
I have bought an EARU EAWCB-TY-2P 63A and it doesn’t show the power, current and voltage data on Home Assistant. It appears as a simple switch. In the SmartLife app appear the oders values.
Any sugestion?
Look at hidden sensors for your device - click on [+ N objects] on the Sensors section.
If the power/voltage/current are hidden, open the sensor settings and activate these sensors.
Is your device Wi-Fi or ZigBee?
Open the device settings and download diagnostic data. It is a json text file.
Look at “category”: “???”
If your category is not “dlq” you can create an issue in github and ask to update the tuya integration to support your category.
I have the same problem, does it work?
@vlavorini: I have the same problem with the same product: EAYCBM-Z-2P It is a EARU Zigbee Circuit Breaker with leakage protection. Could you solve the problem? Please contact me. Thank you.
yo puedo mostrar todos los datos en home asistem
