Suggestion to add system status to the Roth Touchline integration.
Status is already available in the python library under “get_status” which uses the: <i><n>R0.SystemStatus</n></I>
call to the Touchline controller.
Currently one of my thermostats battery is low, causing system status to be “3”:
R0.SystemStatus: 3
I don’t think it can report individually for each thermostat so we will have to settle for a general status for the whole controller.
Even the official app only reports:
“Connection problems help”
“The warning triangle indicates that there are problems with a connection module or thermostat.”
Still think the system status would be useful never the less.
wow that’s a great idea to use no changes to discover disconnected thermostats!
I finally got around to test your bridge, but I can’t get it to connect to my MQTT broker:
