been using for a while with no real issues, if you merge or move entities from one to another, those entities from the orginal device will be move to the other device and thus the original device can be empty ( imo this is expected behaviour), If you remove the device from the merge or remove the entities from the new devcie they do move back to original device with no problem.
in this example ii have merged a Zigbee wall socket and a Shelly PM mini so I get a switch and power readings in the one device.
the Shelly device now has no entities, but it is still required as it has the visit link to open the Shelly webpage, granted it would be nice for ALL info for all device to show in the Main new device, but this is not an issue really.
Yea, itās really frustrating to not see feature parity between the two. Particularly because it creates confusion about the standard and best-practice approachā¦
I can (probably) see why itās not possible to have device assignment in YAML. But why canāt we have all options in the UI. Iām particularly interested in precision of generic thermostat.
I must have missed the release announcement when this was implemented! but as of Feb 2025 this feature is available. In the Template you can select a device to link it to. Then in the device info it appears.
Yes, the feature is available, but not available for yaml template entities. Which is why this remains open. This feature was added sometime in the past year.
Iām glad that when I add a template sensor via the UI, it allows me to attach it to a device.
As far as I see, this uses Home Assistantās internal device_idābased matching mechanism, which seems too fragile to expose in YAML, and since the id and friendly_name still are not siplit on the UI, Iām afraid this feature will not be available for YAML any time soon.
Do you see any chance this could be supported?
My Usecase
I have been managing my entire HA configuration with Ansible (for 9 years), so I have many automatically generated configuration parts, e.g. my APC battery packās output power calculation and its energy sensor.
It wonāt be added anytime soon. At a bare minimum, development canāt start until after legacy templates are fully deprecated and removed from the system.
