Add the ability to change the order of actions and triggers
Hi to all. This is my first time writing on the forum.
Add the ability to move action above or below in the UI automation editor. Now you have to delete the last action if you need to insert an action between two existing actions.
In my opinion, this would make it easier to create automations
Hi Bogdan and welcome to the community.
As of HA version 2022.9 the automation editor now has the ability to reorder actions, conditions and triggers.
Click on the top right hamburger, scroll down and click on reorder, then you can either use the keypad type icon to drag and drop or use the up and down arrow keys.
Thanks, had the same problem
