Hi all,
I recently came across deCONZ and stated using it as an alternative to other hubs as it ties in so nicely to Home-Assistant.
I am using the docker community version of deCONZ by Marthoc as suggested by the documentation. Most of my smart home software is running on docker on a fairly decent server, mainly because I can use Traefik and expose them over https to my local and the world.
However unfortunately the WebSocket is exposed over port 443, while the docker container allows this, at present Home-Assistant only allows the configuration of port 80 and not the web socket port when configuring the integration. This has led to me needing another server just so I can expose the required ports.
Would it be possible to dd the ability to change the web socket port for the deCONZ integration when manually defining the gateway.
