I’m using the notify service based on the rest platform to invoke notifications on another instance of home assistant by calling the webhook url of the automation which works fine however I am unable to pass custom data to the service call as it simply doesn’t reach the destination. The only data I am able to pass is whatever I set up in the component definition in the config file. Even templating the value wasn’t possible.
Example:
Service Definition
- name: test
platform: rest
resource: url
method: POST_JSON
title_param_name: title
target: passes fine
url: so does this
Service Call:
service: notify.test
title: test
message: test
image: test but this won't pass through
Is there a chance to get the support for data implemented?
- name: test
platform: rest
resource: url
method: POST_JSON
data_template:
image: '{{ data.image }}'
I didn’t realize I had to use data.image and I was using image instead. I’ve been able to pass the data variable through the service call and I could see it in the rest call.
I guess we can close this
Yeah I just had such a complicated setup I left it cause it worked until I upgraded some other services and HASS broke. There was lot of breaking changes and I definitely procrastinate too much.
I’m currently fighting with an issue I described in another feature request which is kind of annoying.
