Would be great if the option was there to add multiple MFAs. Currently you can only add the one, but if lost your phone and was logged out (cache cleared) you could lose access, but it would be great to have another MFA on an extra device to eliminate this.
You should be able to do this already. When setting up MFA using an app to generate (TOTP) codes, simply ignore the QR code and then copy the alphanumeric code and keep it safe.
You can put the alphanumeric code into as many (TOTP) code generator apps as you like.
