Add the state of a counter to a template
trying to add the state of a counter (number/integer) to a template.
tried these 2 options unsuccessfully; can you help pinpoint the issue(s) or suggest a better approach? Thanks!
- image:
    url: >-
       {% set N = states('counter.news_rss_counter') %}
       {{ state_attr('sensor.radio_canada_rss', 'entries')[N].image }}
- image:
    url: "{{ state_attr('sensor.radio_canada_rss', 'entries')[{{ states('counter.news_rss_counter') }}].image }}"
Try this:
- image:
    url: >-
       {% set N = states('counter.news_rss_counter')|int %}
Thank you, that was it =)
Everything works as expected but one more thing to improve my skills :
the “image.test” entity created will just contain the url/link and not the image file itself; so it is normal not to find the actual image under the local www folder and using the image entity in a card will just fetch the image from the url; are my assumptions correct?
Correct.
The image is fetched for display in the frontend when you put the entity in a picture card or similar and your web browser visits that page.
Perfect. Thanks for your support, much appreciated.
