This blueprint allows you to create a script to add an item to a to-do list that is pre-configured to a specific to-do list.
It is meant to be added to your dashboard. When activated, it will ask the user for the item to add.
This blueprint requires Home Assistant 2024.3 or later.
blueprint:
description: >-
A script that adds an item to a to-do list.
domain: script
input:
to_do_list:
selector:
entity:
domain: todo
item_label:
selector:
text:
default: Item
mode: queued
fields:
item:
selector:
text:
name: !input item_label
required: true
sequence:
- service: todo.add_item
item: "{{ item }}"
entity_id: !input to_do_list
