I came that far …
But now I am not sure how the right syntax has to look like if I want to combine “Print Time Left” + “Current Time”?
This is quite painful right now. This is probably the safest way to get this value:
{% set t = states('sensor.octoprint_print_time_left').split(':') | map('float', none) | list %}
{% set hours, minutes, seconds = t if t | length == 3 else (0, 0, 0) %}
{% set remaining = timedelta(hours, minutes, seconds) %}
{{ now() + remaining }}
You can put that directly into a template sensor and it’ll tell you the timestamp. As always, this is not the only way to do it. There’s a number of other ways too.
Here’s yet another way to do add the remaining time to the current time (suitable for use in a Template Sensor):
{% set t = strptime(states('sensor.octoprint_print_time_left'), '%H:%M:%S', today_at('00:00:00')).time() %}
{{ now() + timedelta(hours=t.hour, minutes=t.minute, seconds=t.second) }}
Perfect! I also formatted the output to display HH:MM
{{ (now() + timedelta(hours=t.hour, minutes=t.minute, seconds=t.second)).strftime("%H:%M") }}
… and wrapped it in a custom sensor in the config:
# Octoprint ETA
sensors:
octopi_print_eta:
value_template: >
friendly_name: "Octoprint ETA"
Thanks for this @123 (far too often when I come across a correct answer it is yours!!!), and @pixelwave for the sensor. I have moved all my sensors to templates so thought I’d share my config entry for anyone else who comes across this:
template:
# Octoprint ETA
- sensor:
icon: mdi:timer-sand
state: >
