I have two sensors, actually net _inbound_power and solar_generated_power displaying nicely in a simple history-graph. However, I would like to display the sum of these two sensor values on the same graph. Is there a simple way to do this? house_consumption = net_inbound_power + solar_generated_power
@tom_l that is really, really helpful. Much appreciated! You’ve given me the solution and further reading… that’s great and I’ll dig into this some more.
Hi! I was trying to do the same as described above. I manage to sum the values from my sensors - in my case current from each of 3 phases. I can see the new entity with the right value but when I try to add it to the statistics graph card, it is just not possible. It does not appear on the list of entities. I can add it to an entity card or gauge card etc. but not to the statistics graph one.
Could anyone suggest what it is that I am doing wrong?
It needs a state_class: measurement Which is not supported by the legacy template sensor platform. You can either add it using Customize or use the new template sensor integration.
It may also need device_class: power which both the integration and legacy sensor platform support.
