Please add unique_id support to history stats sensor, and honestly to all other entities – I think it should work globally anywhere.
Yes, please!!!
It’s way better to be able to update the entities from the UI!
Hope this will come soon.
I just went to use this integration for the first time because it’s a perfect solution for a sensor I wanted to build, but I can’t believe unique_id isn’t supported…
A start would be to add unique_id
to the tables statistics_meta
and states_meta
. This is not invasive and might help resolve/prevent problems caused by renaming entity_id
or rediscovery of for example zigbee entities.
