To better understand the usage of energy in the home I have a number of devices with smartplugs. The scale of you usage gets more apparent when there is also an overview of the amount of used energy that is not monitored. I have a manual solution to that (a template sensor which subtracts all the monitored devices from the total consumption). This is very prone to errors as I need to add all new smartplugs manually. I would really like to be able to enable/disable this sensor in the energy dashboard config.
@mdehaas An old thread I stumbled on.
Do you use the Riemann Integration for the tracking of energy of the individual plugs?
If so, I tried your suggestion but I get a weird total of unmonitored energy consumption as if I use the current readings of the meter (with the P1-meter) then the total almost matches the total of the meter.
What am I doing wrong?
Update: O, I guess it should actually work only I can’t add the sensor I created as an individual device in HA. My sensor looks like this:
Update: after being away for a few hours I decided to give it another try to get the Unmonitored-sensor in the energy-dashboard but couldn’t be chosen. After putting a line state_class: total in the sensor I could add it but although the value increases the bar remains empty.
Another update: a couple of minutes later the bar started to progress.
