Hi, I’m using an add up helper for several entities. If only one of these entities is out of service, the helper’s output is “unknown”.
Is there a setting, that the helper adds up the remaining entities (without these out of service entities) and shows a valid number?
You would have to create a template sensor instead.
template:
- sensor:
- name: Total
unit_of_measurement: "W"
state: "{{ states('sensor.one')|float(0) + states('sensor.two')|float(0) + states('sensor.three')|float(0) }}"
The float filter default (0) replaces unavailable entities with zero.
If you are going to add a sensor, you could as well:
- name: "Unknown entities count"
state: >
{{ states.sensor
|selectattr('state', 'eq', 'unknown')
|list|count }}
Hi, thank you!
For >80 sensors this seems to be not an appropriate way… Any other solutions?
Something like this:
Or this:
I missed the point, didn’t I
This sums all sensors not unknown or unavailable and having “temp” in their object_id (the part ofter sensor. )
{{ states.sensor
|rejectattr('state', 'eq', 'unknown')
|rejectattr('state', 'eq', 'unavailable')
|selectattr('object_id', 'search', 'temp')
|map(attribute='state')
|map('float')
|sum
