I enabled the new home assistant authorization and on a restart, it let me set up my admin user with a password. I don’t have any menu item to add new users though, and when navigating to http://myhaasip:8123/config/users/ and trying to add a user I get an authorization error.
Thx @awarecan for the reply.
Have - type: trusted_networks enabled, but on login i get only Home Assistant Local and Legacy API Password.
BTW: The log says on startup:
2018-08-22 02:19:34 WARNING (MainThread) [homeassistant.components.http] Experimental auth api enabled and legacy_api_password support enabled. Please use access_token instead api_password, although you can still use legacy api_password
