Add variable or input to data_template?
Hey all,
I am working on a volume control Blueprint that uses an Ikea rotating knob.
I have successfully got it to work based on the below, however, I can’t seem to get it to work using inputs to pick the entity_id for the player. Any assistance/ feedback would be greatly appreciated.
- variables:
    command: '{{ trigger.event.data.command }}'
    cluster_id: '{{ trigger.event.data.cluster_id }}'
    endpoint_id: '{{ trigger.event.data.endpoint_id }}'
    args: '{{ trigger.event.data.args }}'
- choose:
  - conditions:
    - '{{ command == ''stop'' }}'
    - '{{ cluster_id == 8 }}'
    - '{{ endpoint_id == 1 }}'
    sequence:
    - delay: 0.1
  - conditions:
    - '{{ command == ''toggle'' }}'
    - '{{ cluster_id == 6 }}'
    sequence:
    - wait_for_trigger:
      - platform: event
        event_type: zha_event
        event_data:
          device_id: !input 'remote'
          endpoint_id: 1
          cluster_id: 8
          command: 'toggle'
      timeout:
        milliseconds: 500
      continue_on_timeout: true
    - service: media_player.media_play_pause
      target: !input 'media_player'
  - conditions:
    - '{{ command == ''step'' }}'
    - '{{ args == [0, 1, 0] }}'
    sequence: !input 'double_press'
  - conditions:
    - '{{ args == [1, 1, 0] }}'
    sequence: !input 'triple_press'
  - conditions:
    - '{{ command == ''move'' }}'
    - '{{ args == [0, 195] }}'
    sequence:
      repeat:
        while:
        - condition: template
          value_template: "{{ repeat.index < 2 }}"
        sequence:
        - service: media_player.volume_set
          entity_id: media_player.spotify_donkeyrollerz
          data_template:
            volume_level: "{{ state_attr('media_player.spotify_donkeyrollerz' , 'volume_level') | float + 0.05 }}"
        - delay: 1.0
  - conditions:
    - '{{ args == [1, 195] }}'
    sequence:
      repeat:
        while:
        sequence:
          data_template:
            volume_level: "{{ state_attr('media_player.spotify_donkeyrollerz' , 'volume_level') | float - 0.05 }}"
        - delay: 1.0
