Add Wemo plugs to an "area"? Devices not showing under "integrations"
I’m using some Wemo switches and they are working great. They are automatically discovered and automatically added to my lovelace home page (I’m still playing with things and have left lovelace to manage itself) which is amazing.
The issue is that when I go to the “Integrations” panel under configuration there are no devices listed under the Wemo integration which means that I can’t add the switches to an area (adding to an areas causes automatic lovelace to place the device into a panel with other devices in that area).
Is this expected? Anything I can do to force the devices to an area or is that support just not built into the wemo integration?
On a related note, I tried hard coding the plugs per the Wemo component docs and they still don’t show under “integrations”.
Are there more details I need to provide to have some help? Is this expected behaviour?
any luck figuring this out?
Sorry, no one replied to me. I tried to look into the code to see where an integration would add a device but I couldn’t find it. I guess it just doesn’t work for wemo
Yeah wemo don’t have devices in integration and can’t be added to an area either.
Thanks David.
