But maybe there’s something wrong… you could also temporarily add some log here and there to check what’s going on, or even simply the value i.e. if (lazy650Enabled) {ESP_LOGI("roomba", "lazy650Enabled is true");} or unconditionally simply passing the value as variable arg.
Experimenting with filters is a good idea… removing translations from component code and leaving raw values flow, eventually manipulated at the filters stage, so that we can easily remove noise.
Please check you added the related sensor within the lambda return value of the custom sensor.
Pay also attention to the position, i.e. last elem of the return value, last elemn of the sensor array defs
I have an additional question regarding the behavior: after the cleaning phase, the “DOCK” button starts to flash; but the activity remains “CLEANING”. Is there any way to intercept the “going to dock” status
I have an additional question regarding the behavior: after the cleaning phase, the “DOCK” button starts to flash; but the activity remains “CLEANING”. Is there any way to intercept the “going to dock” status.
From what I saw in the OI documentation that is not possible .
I don’t know if the automatic dock action is timer based. Maybe we can figure that out.
If it is timer based, we could just change the state based on the timer, but I believe there is some more magic involved in the Roomba.
Yep, I have the feeling that time isn’t the only parameter, because if I move Roomba in another room or area, the research of the dock doesn’t start at the same time. I will do more tests here
I noted this behavior:
Cleaning → Cleaning (Dock button flashing) → Lost (Red Alert triangle on roomba) → Lost
From another point of view, I’m wondering if we can do something with automation or in code when we send command “DOCK” to arbitrary set the activity or another sensor to “Going to DOCK”
In this way we can understand what the roomba is doing after it receives a command, same for “SPOT”, we can manage another status that only “CLEANING” status
So far I had no time to check, so I write my thoughts anyway.
As @wburgers said specs rulez.
I’d check specs then try and see how data flows from device, eventually preparing a truth table
I haven’t had much time either to dive into the idea by @bremby.
I’ve mostly tried to figure out what is wrong with my Roomba and pretty much dove into a rabit hole.
So, last time, I figured that the OI port was damaged, probably due to a short circuit.
So naturally I ordered a new motherboard for my Roomba from AliExpress for about €23.
Because what else could be wrong? The OI port is probably a protected part of the motherboard and so that part is probably damaged.
Took a while to get the new motherboard to the Netherlands.
Last weekend I removed the old motherboard from the device and installed the new one only to find out that it had exactly the same behavior for the OI port.
So apparently it was not the motherboard that was broken .
It has to be one of the sensors or something else.
A few years back, I ordered myself a new battery as the one that came with the Roomba was getting depleted very fast. I kept the old battery laying around just in case.
I inserted the old battery back into the Roomba after the new motherboard install and guess what…
The ESP could read from the OI port again. Inserting the newer battery again, made it spit out bogus.
So I damaged the battery?
Then I started digging more into the battery. There are no smarts in these older NiMH batteries.
It’s just battery cells and a thermistor. No pcb or anything.
With my multimeter I tested both the battery voltage and the thermistor resistance.
The voltage was around 16V after charging, which should be fine.
The thermistor should be between 8.5 and 15.5kΩ at room temperature according to the Roomba service manual.
The old battery gave a value of around 13.6kΩ, the newer battery around 9kΩ, just removed from the Roomba, which could impact the measurement a little.
It should be fine.
So I’m now considering buying another brand new battery.
Before I do so, I’ll hopefully try out a battery from a friend of mine, to see if that indeed solves my issues.
I am completely baffeled that the battery can cause the OI port to go haywire.
Especially since the measurements are okay.
So I’m still a bit lost on what to do next.
Buy a new battery or give up and buy a new robo vacuum.
