this is my main.cpp
#include <Arduino.h>
#include <ESP8266WiFi.h>
#include <ESP8266mDNS.h>
#include <ArduinoOTA.h>
#include <Roomba.h>
#include <PubSubClient.h>
#include <ArduinoJson.h>
#include "config.h"
extern "C" {
#include "user_interface.h"
// Remote debugging over telnet. Just run:
// telnet roomba.local
#if LOGGING
#include <RemoteDebug.h>
#define DLOG(msg, ...) if(Debug.isActive(Debug.DEBUG)){Debug.printf(msg, ##__VA_ARGS__);}
RemoteDebug Debug;
#else
#endif
// Roomba setup
Roomba roomba(&Serial, Roomba::Baud115200);
// Network setup
WiFiClient wifiClient;
// MQTT setup
PubSubClient mqttClient(wifiClient);
const PROGMEM char *commandTopic = MQTT_COMMAND_TOPIC;
const PROGMEM char *statusTopic = MQTT_STATE_TOPIC;
os_timer_t wakeupTimer;
void doneWakeup(void *pArg) {
digitalWrite(BRC_PIN, HIGH);
roomba.start();
DLOG("Done waking up\n");
void wakeup(){
// TODO: There's got to be some black magic here that I'm missing to keep the
// Roomba from going into deep sleep while on the dock. Thinking Cleaner
// had a software solution, so it must be possible:
// http://www.thinkingcleaner.com/setup/problem_solutions/
// I've tried:
// * Pulsing the BRC pin low at various intervals
// * Switching to safe and full modes briefly
// Maybe I could try:
// * Switching on a motor or led very very briefly?
// * Changing the baud rate
// * Setting BRC to input (high impedence) instead of high
// I have noticed sometimes I'll get a sensor packet while the BRC pin is
// pulsed low but this is super unreliable.
DLOG("Wakeup Roomba\n");
digitalWrite(BRC_PIN, LOW);
// Spin up a timer to bring the BRC_PIN back high again
os_timer_disarm(&wakeupTimer);
// I tried to use a c++ lambda here, but for some reason it'd fail on the 6th
// iteration. I wonder if something is keyed off the function pointer.
os_timer_setfn(&wakeupTimer, doneWakeup, NULL);
os_timer_arm(&wakeupTimer, 1000, false);
bool performCommand(const char *cmdchar) {
// TODO: do this only if necessary
wakeup();
// Char* string comparisons dont always work
String cmd(cmdchar);
// MQTT protocol commands
if (cmd == "turn_on") {
DLOG("Turning on\n");
roomba.cover();
} else if (cmd == "turn_off") {
DLOG("Turning off\n");
roomba.power();
} else if (cmd == "toggle") {
DLOG("Toggling\n");
roomba.cover();
} else if (cmd == "stop") {
DLOG("Stopping\n");
roomba.cover();
} else if (cmd == "clean_spot") {
DLOG("Cleaning Spot\n");
roomba.spot();
} else if (cmd == "locate") {
DLOG("Locating\n");
// TODO
} else if (cmd == "return_to_base") {
DLOG("Returning to Base\n");
roomba.dock();
} else {
return false;
return true;
void mqttCallback(char *topic, byte *payload, unsigned int length) {
DLOG("Received mqtt callback for topic %s\n", topic);
if (strcmp(commandTopic, topic) == 0) {
// turn payload into a null terminated string
char *cmd = (char *)malloc(length + 1);
memcpy(cmd, payload, length);
cmd[length] = 0;
if(!performCommand(cmd)) {
DLOG("Unknown command %s\n", cmd);
free(cmd);
void debugCallback() {
String cmd = Debug.getLastCommand();
// Debugging commands via telnet
if (performCommand(cmd.c_str())) {
} else if (cmd == "quit") {
DLOG("Stopping Roomba\n");
Serial.write(173);
} else if (cmd == "rreset") {
DLOG("Resetting Roomba\n");
roomba.reset();
} else if (cmd == "mqtthello") {
mqttClient.publish("vacuum/hello", "hello there");
} else if (cmd == "version") {
const char compile_date[] = __DATE__ " " __TIME__;
DLOG("Compiled on: %s\n", compile_date);
} else {
DLOG("Unknown command %s\n", cmd.c_str());
void setup() {
pinMode(BRC_PIN, OUTPUT);
// Set Hostname.
String hostname(HOSTNAME);
WiFi.hostname(hostname);
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
ArduinoOTA.setHostname((const char *)hostname.c_str());
ArduinoOTA.begin();
mqttClient.setServer(MQTT_SERVER, 1883);
mqttClient.setCallback(mqttCallback);
#if LOGGING
Debug.begin((const char *)hostname.c_str());
Debug.setResetCmdEnabled(true);
Debug.setCallBackProjectCmds(debugCallback);
Debug.setSerialEnabled(false);
#endif
roomba.start();
void reconnect() {
DLOG("Attempting MQTT connection...\n");
// Attempt to connect
if (mqttClient.connect(HOSTNAME)) {
DLOG("MQTT connected\n");
mqttClient.subscribe(commandTopic);
} else {
DLOG("MQTT failed rc=%d try again in 5 seconds\n", mqttClient.state());
void sendStatus() {
// Flush serial buffers
while (Serial.available()) {
Serial.read();
uint8_t sensors[] = {
Roomba::SensorDistance, // 2 bytes, mm, signed
Roomba::SensorChargingState, // 1 byte
Roomba::SensorVoltage, // 2 bytes, mV, unsigned
Roomba::SensorCurrent, // 2 bytes, mA, signed
Roomba::SensorBatteryCharge, // 2 bytes, mAh, unsigned
Roomba::SensorBatteryCapacity // 2 bytes, mAh, unsigned
uint8_t values[11];
bool success = roomba.getSensorsList(sensors, sizeof(sensors), values, 11);
if (!success) {
DLOG("Failed to read sensor values from Roomba\n");
return;
int16_t distance = values[0] * 256 + values[1];
uint8_t chargingState = values[2];
uint16_t voltage = values[3] * 256 + values[4];
int16_t current = values[5] * 256 + values[6];
uint16_t charge = values[7] * 256 + values[8];
uint16_t capacity = values[9] * 256 + values[10];
DLOG("Got sensor values Distance:%dmm ChargingState:%d Voltage:%dmV Current:%dmA Charge:%dmAh Capacity:%dmAh\n", distance, chargingState, voltage, current, charge, capacity);
bool cleaning = false;
bool docked = false;
String state;
if (current < -300) {
cleaning = true;
} else if (current > -50) {
docked = true;
StaticJsonBuffer<200> jsonBuffer;
JsonObject& root = jsonBuffer.createObject();
root["battery_level"] = (charge * 100)/capacity;
root["cleaning"] = cleaning;
root["docked"] = docked;
root["charging"] = chargingState == Roomba::ChargeStateReconditioningCharging
|| chargingState == Roomba::ChargeStateFullChanrging
|| chargingState == Roomba::ChargeStateTrickleCharging;
root["voltage"] = voltage;
root["current"] = current;
root["charge"] = charge;
String jsonStr;
root.printTo(jsonStr);
mqttClient.publish(statusTopic, jsonStr.c_str());
int lastStateMsgTime = 0;
int lastWakeupTime = 0;
void loop() {
long now = millis();
// If MQTT client can't connect to broker, then reconnect
if (!mqttClient.connected()) {
reconnect();
} else {
if (now - lastWakeupTime > 50000) {
lastWakeupTime = now;
wakeup();
if (now - lastStateMsgTime > 1000) {
lastStateMsgTime = now;
sendStatus();
ArduinoOTA.handle();
yield();
Debug.handle();
mqttClient.loop();
