Add xiaomi gateway to ha
after adding a xiaomi gateway (aqara) to home assistant via integration, the following alert appears:.
I can’t add the gateway to home assistant
is there a solution to this problem?
i have other gateways added and there is no problem with these
I have this Aqara hub and have given up on it. As far as I know it’s not possible due to the app, Mi Home, doesn’t let you access the API key to connect :frowning:
the integration does not work on the aqara model you have … i was talking about the xiaomi version 2 model with radio. the same gateway worked when integrated via config.yaml, but now via integrations it results in that error
