Hey,
any one know do i add the new Xiaomi Temperature and Humidity Sensor to my HA?
i do not see it via my HA,
Thanks!
Hey,
Thanks!
Hey mp3llll,
First you must add it to the Xiaomi gateway, once this is done and you have HA setup to connect to the gateway, you will need to restart HA, and it should show up as two sensors, looking something like this:
- sensor.humidity_xxxxxxxxxxxxxx
- sensor.temperature_xxxxxxxxxxxxx
I hope that helps.
Mine are picked up automatically if they are present in the App.
yes this what i thanks, will be show automatically…
ok as TinyDoT say, need to restart HA, i did not try it
Thanks i will try/
Yes!! Show after restart! Thanks
Hey all!
I’ve runned into the same problem but restarting HA have not halped me at all.
I do connect the gateway with HA properly tho since it adds my yeelight automaticly, still don’t see the temperature sensor.
Besides doing the gateway configuration, do i need to do something else if i want the sensor to be working? Anything from the Mi Home app or something like that?
Thanks all.
Just confirming, you have enabled LAN access in the gateway and setup the Gateway component
Is there anything in the logs
Yeah sure, the gateway syncs well, even it detects my yeelight from aqara’s component, the only thing is that i can’t see my temperature and humidity sensor
Yeelights aren’t connected to the gateway. Can you see the sensor in the mi home app?
Yeah that’s right, the yeelight can work itself, but once i’ve connected the gateway, it was appearing twice, and i have removed the “light:” configuration and it is working by the gateway.
I can’t see the sensor in the mi home app neighter, but to be honest i don’t understand mi home app very well.
Thanks guys
you need to add the device to the gateway before home assistant can see it
Or if you just want the sensors and you are using hassio, you can use an addon with a cheap stick: https://github.com/danielwelch/hassio-zigbee2mqtt
As I wrote, yeelights do not connect to the gateway, and read the opening post of this topic. Solution to your “problem” is in post #2.
Oh i see! Thank you very much guys, i’ll try with the mi home app, and if i still can’t add it i’ll try to ask in aqara formus since it’s more suitable there.
Sincerely thank you all very much.
OP has the gateway, so for starters i think best get used to using the gateway then if needed move to another solution.
i am using the zigbee2mqtt also as well as the gateway to compare reliability in both. still pretty even at the moment.
Not fussed about the gateways trying calling home as they have been capped at the knees with that and are in separate network with internet access
Completely agree, if you have the gateway start with that.
I’ve been using the gateway as well (xiaomi) but plan to get fully on zigbee2mqtt because of flexibility. I hate that I am dependent on the MiHome app for pairing and firmware updates quirks. There was a period when their (Xiaomi MiHome) app was broken on IOS for around 2 weeks.
You can start the pairing from Home assistant by calling the service xiaomi_aqara.add_device from the developers panel. just need to add the json for the gateway you want to pair with.
{{“gw_mac:” “xxgateway_macxx”}}
that way no need to use the mihome app unless you wish to update the gateways
I have a Xiaomi temperature sensor with barometric pressure sensor. Everything is working great, it’s auto discovered, but for pressure it’s showing raw pressure, not the widely used sea level pressure (corrected with your elevation).
Is there any formula in HA to convert raw pressure reading to the more used mean sea level?
Mean sea level pressure calculator (converter) – Simple formula
On the page is the formula too:
p0 = Calculated mean sea level pressure
p1 = Measured/barometric pressure
T = Measured air temperature:
?? = Elevation of measured data
p0 =p1 (1-0,0065h / (T + 0,0065h +273,15))^-5,257
…but how do I use this to correct reading for my Xiaomi sensor?
Ever get any help with this?
You do this with templates. Say your absolute pressure looks like this:
- platform: mqtt
name: "Man Cave Air Pressure"
state_topic: "tele/sonoff9/SENSOR"
value_template: "{{ value_json['BMP280'].Pressure }}"
unit_of_measurement: "hPa"
It doesn’t matter what sort of sensor it is - you just need the name to plug into a template. Create a template like the following:
sensors:
man_cave_pressure_msl:
friendly_name: "Man Cave Air Pressure MSL"
unit_of_measurement: hPa
value_template: "{{ (states('sensor.man_cave_air_pressure')|float * (1 - (0.0065 * 175) / (states('sensor.man_cave_temperature')|float + (0.0065 * 175) + 273.15)) ** -5.257) | round(1) }}"
icon_template: mdi:gauge
In this template substitute the Xiaomi temperature and pressure sensor names to replace the example ones. The number “175” is the elevation in metres above sea level of your sensor. Substitute your elevation, all other figures should remain the same.
Input and output sensors should look like:
sensor.man_cave_air_pressure 998.1
sensor.man_cave_pressure_msl 1018.6
I could fix my installation with your hint as well. One open point is still left: How to include the reading in a device area? Thank you.
