When using Samsung Multipurpose Sensors (CentraLite 3321-S) with the Smartthings integration, the devices appear with entities for X, Y, and Z coordinates, but when I pair these sensors directly with ZHA, those coordinate entities don’t show up.
If I click “Manage Clusters” on the device, there’s a cluster called CentraLiteAccelCluster with these attributes:
acceleration (id: 0x0010)
motion_threshold (id: 0x0002)
motion_threshold_multiplier (id: 0x0000)
x_axis (id: 0x0012)
y_axis (id: 0x0013)
z_axis (id: 0x0014)
When I listen to ‘zha_event’ on the Developer Tools page, I see axis events firing when I tilt and move the sensor around.
Event 38 fired 9:39 AM:
"event_type": "zha_event",
"data": {
"device_ieee": "00:0d:6f:00:0e:35:89:f9",
"unique_id": "00:0d:6f:00:0e:35:89:f9:1:0xfc02",
"device_id": "8fcebf983eb17a9688d137ddc896fa97",
"endpoint_id": 1,
"cluster_id": 64514,
"command": "attribute_updated",
"args": {
"attribute_id": 20,
"attribute_name": "z_axis",
"value": -1013
"origin": "LOCAL",
"time_fired": "2021-01-22T15:39:37.964365+00:00",
"context": {
"id": "4159bd838d262ad76c17b5377c2a0b4a",
"parent_id": null,
"user_id": null
Event 37 fired 9:39 AM:
"data": {
"endpoint_id": 1,
"args": {
"attribute_id": 19,
"attribute_name": "y_axis",
"value": -2
"origin": "LOCAL",
"time_fired": "2021-01-22T15:39:37.963979+00:00",
"context": {
"id": "f5bec08670147a6beac0d35c27270d76",
"parent_id": null,
"user_id": null
Event 36 fired 9:39 AM:
"data": {
"endpoint_id": 1,
"args": {
"attribute_id": 18,
"attribute_name": "x_axis",
"value": -24
"origin": "LOCAL",
"time_fired": "2021-01-22T15:39:37.963514+00:00",
"context": {
"id": "291d38c888d11b1e9d80cf46a59a1358",
"parent_id": null,
"user_id": null
I found a related issue on github where this functionality was added to the Smartthings Integration:
Add SmartThings sensor support for Three Axis #21841
I also found a related issue where acceleration was added to the ZHA integration for this device, but only as a binary sensor for movement. The three-axis attributes were not included.
Add SmartThingsAccelCluster to ZHA binary_sensor #21609
I found several other discussions about this in other subforums and on reddit. (The forum won’t let me post more than two links).
- SmartThings Multipurpose Sensor (2018) with HUSBZB-1
- ZIGBEE (ZHA): Get a Cluster Attribute that isn’t normally tracked
- Centralite 3321S - SmartThings Multipurpose Sensor
I’d love to help build this, but I’m still really new to Home Assistant and don’t have the skills yet.
