Added support for Vaillant Thermostat, how to integrate in official release
Hello I’m using protherm (same as sounier Duval, Bulex) and MiGo 2.2.0.0 app please where I can find secret key? PM me please
Hi @MislavMandaric,
I have successfully recovered the API key, but getting a [%key:common::config_flow::error::invalid_auth%] using this configuration:
Client ID: na_client_android_sdbg
Secret key: 28d3etc
Name: my e-mail address that I use to login
Password: hunter2
user prefix: sdbg
App version: 2.2.0.0
Do you have any ideas? Or any one else maybe? Thanks so much!
I see this question has been asked before, but I never found a solution posted. I’m 100% sure my password is correct.
Hi, I am using vaillant vSmart Pro in China; however, in China, people have to use another vaillant app on the phone (it seems it is the same case in Turkey). Is there a way to integrate my vaillant vSmart pro into Homeassistant?
For me, it worked, but I had to specifically download the 1.0.4.0 Vaillant APK. Then used your exact settings, and the v4 client secret in the files, which you will find if you look up na_client_android_vaillant in the apk
I have finally gotten everything to work. I have a couple of questions regarding the configuration I’m using. I’m using the following:
service: climate.set_temperature
  temperature: 19
  entity_id: climate.vaillant_vsmart_xxx
and
  temperature: 15
When I run the automation, the Vaillant app shows the temperature being changed. So for example, when running the 15, in Vaillant app it changes to 15 degrees. It takes a couple of minutes to see the change in the Thermostat card. Is this expected?
Furthermore, the Lovelace card stays put on Heat, although it should be not heating as it’s going to 15 degrees from a higher temperature. It does show Idle - Winter.
I would like to just use Home and Away for this, with Home being 19 degrees and Away being 15 degrees. Do you have any tips on how to do this?
Hi all,
What i am doing wrong ?
On my smartphone i use ( and register ) on “sensoAPP 3.1.0”, it’s the wrong app ?
Do i need to install and register on “Vaillant vSMART Control_v2.1.6.0” ?
Hello, Thank you for your information.
I find the specified data but I don’t know which identifier to use?
should I take the word before na_client_android_vaillant or the one after?
Thank
PI 4 32 bits
Home Assistant 2022.11.0
Supervisor 2022.10.0
Operating System 9.3
Interface utilisateur : 20221102.1 - latest
Pac Vaillant
VR920
Bonjour, Merci pour tes informations.
Je retrouve les données spécifiées mais je ne sais pas quel identifiant prendre ?
je dois prendre le mot avant na_client_android_vaillant ou celui d’apres ?
Merci
It’s the code after v4. Starts with 28d3
Hi, how can I get the secret client and ID? I have a netatmo (developer) account where I already had the SECRET and ID credentials.
Then he also asks me PREFIX and APP VERSION. can you help me?
Raspberry PI 3 32bit
Home Assistant 2022.11.1
Supervisor: 2022.10.2
firmware Vaillant 1029
Ciao Gennaro, visto che non parlo bene inglese, puoi aiutarmi in italiano? Ho appena installato un VSMART ma home assistant mi chiede CLIENT ID e SECRET. Ne avevo uno della NETATMO (mi pare che alcuni lo riescono ad inserire), ma successivamente dovrei inserire PREFIX e APP VERSION. Mi aiuti a venirne a capo? se puoi ti lascio la mia email [email protected].
TI ringrazio infinitamente
Think, but it doesn’t work.
how do i get the secret client?
did you get an answer for the secret client?
Does anybody know how to retrieve the secret_key, ive tried to decompile Vaillant vSMART Control_2.2.0.0_apkcombo.com.apk. But i cant find anything what looks like the key.
also tried to convert classes.dex but no result there
Or better, can anybody PM me the secret key.
Hi pjmaenh,
I’m a SunierDuval user, I’ ve downloaded the MiGo Link 1.11 apk but I’ m not finding the needed keys (api_key, secret_key) could you send it to me or indicate me how can I get them?
Thanks in advance.
Hello
Like you I use the MiGo Link 1.11 apk, I am very interested if you find a solution.
Have you find your id client ? I dont find it!
I give you a personne message ! Tchech it !
Setting
Integration
@minet,
thanks for the secret_key, now i can’t restart :slight_smile:
The system cannot restart because the configuration is not valid: Platform error climate.Vaillant - Integration ‘Vaillant’ not found. Integration error: vaillant - Integration ‘vaillant’ not found.
anybody an idea whats wrong, i didn’t installed an integration?
Hello, I have just installed a new heater. This is controlled by a sensoCOMFORT VRC 720. I can’t find the ID. It looks like it’s not me! Exact? What should I do ? Where to find the ID!? Thanks
