Added support for Vaillant Thermostat, how to integrate in official release
i also need the secret key (MiGoLink), maybe this plugin is not compatible with MiGoLink?
@MislavMandaric
Guys, the key is like a password - no-one wants to paste it plain on internet. Search the forum, there are multiple posts with explanation on how to find it.
Hello
A new version of Migolink (v2.3.1) is available.
This version introduces a new login process and now we can use this application with Windows 10 using BlueStacks or with Windows 11 by installing the Google Play store.
@MislavMandaric, do you think this could open a door to integration into Hassio?
Thank you
i found the password in valliant apk but seems not exist in migo link apk
Maybe @MislavMandaric can try to apply to dev prpgram here Vaillant Group - API Developer Programme
"I had the same issue and here’s what I did to fix it:
  1. Logged out from the iOS app and the Android app.
  2. Changed my password (requested from the iOS app).
  3. Logged in FIRST from the Android app.
  4. Then from the iOS app.
  5. Finally, from HomeAssistant.
If I logged in first from the iOS app, the Android app and HomeAssistant would not log in and I would get the error message [%key:common::config_flow::error::invalid_auth%] This solution worked for me, although I have no idea why or how."
can you send me the API ? thnx
Dear Samuel,
Would you be able to send me the API and Secret key?
Thank you in advance!
Best Regards,
Darek
With migo link?
If possibile i need migo link secret code since seems impossibile to found decompiling the app
Hey this works perfectly with migo link
thanks for the integration.
I installed the integration without any problem but impossible to connect with my MiGo credentials (saunier duval)
What is the Client secert for my Vaillant vSmart
Where do I find details for Migo Link android app? Can someone send me please?
https://www.saunierduval.fr/particulier/nos-produits/connectivite/l-application-migo-link/
Hey have you solved this yet? Since you didn’t get any answer and I do now have the same problem.
Hello! Does anyone know how to get the indoor and outdoor temperature? The integration just exposes the hot water temp, but would be useful to get these other 2 values! Thanks for your work!
Please send me in PM API_KEY, SECRET_KEY, APP_VERSION and USER_PREFIX for vSmart app.
Thank You
Hi, could you provide me with the secret ID and secret client for the embedding of the app in my HA setup. Thanks a lot for th ehelp
HI Samuel, please could you (or someone else) PM me the Client ID and Client secret so I can use HA with my heating.
Thanks!
