My Supervisor was working fine until I decided to add the Wifi password so I could have a second access in case I had to cut cords.
But I was fooled by the UI and added my wifi without a password. No I get the error below and I’m not able to change the password again. Do you have any tip on how to solve it?
20-12-07 21:14:36 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 422, in _handle_request
resp = await self._request_handler(request)
File "/usr/local/lib/python3.8/site-packages/sentry_sdk/integrations/aiohttp.py", line 123, in sentry_app_handle
reraise(*_capture_exception(hub))
File "/usr/local/lib/python3.8/site-packages/sentry_sdk/_compat.py", line 54, in reraise
raise value
File "/usr/local/lib/python3.8/site-packages/sentry_sdk/integrations/aiohttp.py", line 113, in sentry_app_handle
response = await old_handle(self, request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_app.py", line 499, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_middlewares.py", line 118, in impl
return await handler(request)
File "/usr/src/supervisor/supervisor/api/security.py", line 133, in system_validation
File "/usr/src/supervisor/supervisor/api/security.py", line 195, in token_validation
File "/usr/src/supervisor/supervisor/api/utils.py", line 60, in wrap_api
answer = await method(api, *args, **kwargs)
File "/usr/src/supervisor/supervisor/api/network.py", line 166, in info
for interface in self.sys_host.network.interfaces
File "/usr/src/supervisor/supervisor/host/network.py", line 54, in interfaces
interfaces.append(Interface.from_dbus_interface(inet))
File "/usr/src/supervisor/supervisor/host/network.py", line 296, in from_dbus_interface
Interface._map_nm_wifi(inet),
File "/usr/src/supervisor/supervisor/host/network.py", line 341, in _map_nm_wifi
if inet.settings.wireless_security.key_mgmt == "none":
AttributeError: 'NoneType' object has no attribute 'key_mgmt'
