Hello i currently have (2) vista 20p alarm panels. (1) for my house and (1) for a detached garage. I purchased a second Alarm Decoder RPI this past week thinking that if i just add another Alarm Decoder device to Home Assistant i would be able to manage/control each alarm panel independently. for the most part everything is working perfectly however the biggest issue I’m running into is with the “Alarm Panel Display” entity. Home Assistant created a separate entity for the second Alarm Decoder device however, Home Assistant is combining the messages for both Alarm Panel Display entities which is causing alot of issues with my Automations & Scripts. i have no way of knowing which message belongs to which Alarm Panel. Any help anyone can provide is extremely apricated!
Not sure what you mean by “message”, here. Only one entity is updated?
It doesn’t seem that that integration is using events.
Thanks for your reply!
when you add the integration it adds 2 entities:
- Alarm Control Panel
- Alarm Panel Display
The alarm panel display is used to obtain the actual status that is displayed on the keypad it self. for some reason when i add the second panel, both of the entities i listed below in my screenshot are being combined as if its one alarm panel even though they are 2 separate integrations/alarm panels.
Hope I’m making sense.
