I’ve searched high and low, but I don’t see any reference to how I could do this
I have 2 separate computers I need to wake on LAN at different times. Is it possible to have them both in there?
This is my config, and it does not work
# Loads default set of integrations. Do not remove.
default_config:
# Text to speech
tts:
- platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
switch:
- platform: wake_on_lan
mac: 70:85:c2:3b:46:17
switch:
name: "Living Room HTPC"
I tried removing the second “switch:” without any luck
(Ignore the duplicate MAC, just for testing)
Any ideas?
A few things:
- use a single
switch
block in what looks to be your configuration.yaml file
- try including the IP addresses of those machines
- play with the
broadcast_port
. Common values for this are 7 or 9, but there may be others depending on your hardware
switch:
host: <IP-ADDRESS-ONE>
broadcast_address: 255.255.255.255 # default value
broadcast_port: 9 # default value
host: <IP-ADDRESS-TWO>
broadcast_port: 9
My WoL switches were hit-or-miss before I started including their IP addresses
They work completely fine for me, I just can’t figure out how to get a second switch, the second shows up all wonky
Let me try again from scratch. Thanks!
