I would like to be able to access this securely from outside my LAN, but there is no way to set a base URL so that I can have my main webserver reverse-SSL-proxy it. DNS is not hosted on my home network, so DNS-based Let’s Encrypt is out of the picture. Since port 80 cannot be directed to the HA machine, HTTP-based machine auth for Let’s Encrypt (which is what my main webserver does) is not an option. Having a “base URL” option like what Jellyfin has would easily solve this, but I cannot find the option anywhere, leading me to believe that it either no longer exists, or was somehow never added in the first place.
It’s not an option as a path isn’t supported.
Correct a path is only part of a URL however you asked for a
The base URL is everything up to the path. e.g.
https://example.duckdns.org:8123/lovelace/home
Base URL: https://example.duckdns.org:8123
- which can be defined as per the link I provided.
Path: /lovelace/home
I need to change the path then. Is that configurable anywhere?
EDIT: This is what I need:
Example from my Jellyfin instance.
This is the old feature request on GitHub: home-assistant/architecture#156
It’s not a feature in Home Assistant today.
Just spend two days trying to find out how to host HA behind a reverse proxy that also serves other applications on https/port 443.
Looks like location “/” needs to be Home Assistant, because the base url is not configurable accordingly.
you could also make use of SNI based reverse-proxy - so you have a sub-domain for each app it is hosting - like ha.mydomain.bla
btw. this request is a duplicate of Configurable WebRoot
Closed as a duplicate please vote and comment at the link provided above.
