Adding a custom card to lovelace
I am trying to add a time picker card to lovelace I found one on github that looks like it is just what i need but im having trouble editing my yaml.
I created a file called ui-lovelace.yaml in my config directory
I added the following to configuration.
lovelace:
mode: yaml
I added time-picker-card.js to my WWW folder
Instructions are telling me to add the following to my “config”
resources:
  • url: /local/time-picker-card.js
    type: module
This is where i am getting dead ended. Exactly where does this go?
why are you not using HACS? It certainly makes the process easy.
i have been avoiding installing that because i have limited experience and from what im reading you can basically “brick” your whole system if it is not done properly
You can use configuration.yaml (see my example bellow):
Or with User Interface:
Configuration > Lovelace Dashboards > Resources > +Add Resource
You are the champ.
I know this is an old thread but I was curious - I have a similar setup, with a .js file and I can see my custom card, Great! However I just modified my .js file and my custom card isn’t picking up the new changes. Is there something I need to do to reload my .js file? I’ve tried deleting the resource and re-adding it but with no luck
Restart HA
developer-tools/yaml
and clear your browser
