Adding a custom device to RFXCOM that RFXMgr sees
Hey all!
I’m in the middle of migrating our HA setup from Domoticz on a Pi 1, to Home Assistant on a Pi 4 - and so far it’s been great! Things have, for the most part, ‘just worked’, which I’m so happy about.
One thing though - while all of our LightwaveRF/Siemens plugs and switches work in the RFXCOM integration, and so do all of our Siemens PIRs (they appear as Byron SX chimes, which they do in RFXMgr too, and that works fine), some of our other Siemens gear isn’t appearing, despite the fact they appear in RFXCOM’s RFXMgr. We have a range of devices from doorbells to door sensors, but they’re not appearing in Home Assistant while auto-add is on.
What’s the way to get these devices to appear? Can I use the information RFXMgr gives me to make a custom device in Home Assistant? Or are these a weird bug?
Any help would be much appreciated!
Many thanks,
-Dan
In Domoticz you can turn ON/OFF protocols in your attached RFXCOM device. In HA there is no such option. Can you make sure the protocol for a device not appearing in HA is enabled?
