right now, I am very frustrated…I used home assistant in docker and so far everything works great. But since 3 days I try to add a floorplan, but it did not work. I read through several posts an youtube videos, but I am not able to find my mistake.
The browser might give you a better error message than just the image not showing up. Is it a problem with the certificate? A 404 not found? Another error?
Could it be file or directory permissions on your ‘www’ folder or the file itself?
I also tried http with the diffrent port. But it did not work either…I also tried to setup up the container in high priority, but it also did not work.
Another issue I am facing is, that I m not able to connect my Synology as integration…even als inputs are correct. Maybe this is somehow connected?
In addition, I am also not able to link ssl certificates to my docker container. They are not fund…I think it has something to do with rights and permission, but I need help to solve it…any idea?
