I trying to add the Aqara Smart Lock U200 to Home Assistant via Google Home but it doesn’t seem to work.
I added the lock without any problems in Google Home and works good, but when I’m trying to add it to home assistant keeps failing.
My preferred thread network is 2 nest devices (Hub Max, Hub 2) and a Google TV streamer.
I have already checked if IPv6 is working in my network. I have already resetted the device twice. I synced the credentials via the Home Assistant companion a lot of times, tried 3 different android devices and 2 iOS but never managed to add it to Home Assistant.
I use docker containers for both Home Assistant and Matter Server. The docker containers are running in a NAS with TrueNAS scale as OS. Using a Ubiquiti Cloud Gateway for my network.
Update 1:
I can see the following in the matter servers log
2024-10-31 18:34:19.518 (Dummy-2) CHIP_ERROR [chip.native.CTL] Discovery timed out
2024-10-31 18:34:23.289 (Dummy-2) CHIP_ERROR [chip.native.EM] Failed to Send CHIP MessageCounter:180863174 on exchange 28753i with Node: <0000000000000000, 0> sendCount: 4 max retries: 4
2024-10-31 18:34:29.625 (Dummy-2) CHIP_ERROR [chip.native.SC] PASESession timed out while waiting for a response from the peer. Expected message type was 33
2024-10-31 18:34:29.625 (Dummy-2) CHIP_ERROR [chip.native.ZCL] Secure Pairing Failed
2024-10-31 18:34:29.625 (Dummy-2) WARNING [chip.ChipDeviceCtrl] Failed to establish secure session to device: src/controller/python/ChipDeviceController-ScriptDevicePairingDelegate.cpp:89: CHIP Error 0x00000003: Incorrect state
2024-10-31 18:34:29.626 (MainThread) ERROR [matter_server.server.client_handler] [140687091445840] Error while handling: commission_with_code: Commission with code failed for node 68.
Update 2:
I added a hue bridge as matter without problems
Update 3:
I recreated the container still the same error in the logs. Do I need a BT device in my Home Assistant instance?
Update 4:
I created the matter server container in a rpi which has bt, no problem adding it to home assistant. So to be added needs a BT adaptor.
Update 5:
Ordered a BT dongle for the NAS to use the matter server there. Hopefully it will work there too.
Update 6:
I was trying for more than one week to add the lock in Home Assistant.
I found this post that can be helpful for others
All the help/tips are welcome ![]()
