Adding a "Scene Switch" - which component should it be?
I want to try to make the Lightwave “Scene Switch” work with RFXTRX component.
Example switch - https://www.amazon.co.uk/LightwaveRF-Controller-Wireless-Lighting-wire-free/dp/B005UM4I0Q/ref=sr_1_1?ie=UTF8&qid=1476810253&sr=8-1&keywords=lightwaverf%2Bgroup&th=1
Is there anything in HA for scene style switches like this? Or should it be made to just fire events - if so can I fire a text event e.g. “Scene1”, “Scene2”?
Neil
I suspect the LWRF switch will send some data over 433MHz which should be caught by HA, whether it’s switch or just an event.
You can then create automations that will trigger a scene or a script based on which button was pressed
