Adding a second (split) Sonos system in my HA
I have two separate Sonos systems (both S2). I have successfully set up one Sonos system in Home Assistant, but when I try to add a second one, it says “Already Configured. Only one configuration possible”
Each Sonos system is on their own VLAN. Currently, nothing is blocking network traffic between these VLAN’s, although multicast/mDNS is not going through.
Is there a workaround so I can control both systems in HA?
Did anyone try this before?
I am dealing with exactly the same issue this morning. Has anyone found a solution?
