Adding a unique ID for RTSP camera
Hello everyone
I’m adding a webcam with rtsp procotol, I edited the config file like this
# config/configuration.yaml
camera:
  - name: sometext
    platform: ffmpeg
    input: -rtsp_transport tcp -i rtsp://user:[email protected]:554/Streaming/Channels/102
The camera appeared in the dashboard and work well, but I can’t manage the camera in WebUI because the camera doens’t have a unique ID
I’ve read the document here This entity does not have a unique ID? - Home Assistant (home-assistant.io)
Accroading to the document:
A few selected integrations (such as template and mqtt) allow the user to define a unique ID.
Then, I tried to add unique_id value in config file like this
camera:
  - name: sometext
    unique_id: somelongrandomstring
    platform: ffmpeg
Then get error like this
homeassistant_1  | 2023-04-19 21:06:07.881 ERROR (MainThread) [homeassistant.config] Invalid config for [camera.ffmpeg]: [unique_id] is an invalid option for [camera.ffmpeg]. Check: camera.ffmpeg->unique_id. (See /config/configuration.yaml, line 32). Please check the docs at https://www.home-assistant.io/integrations/ffmpeg
So, is there any method to manually define a unique ID to the camera?
TIA
Having the same issue. Can anyone help?
dont like our chances but heres hoping.
also not happy with unique id missing errors
It’s not an error, and flagging posts for moderator attention when you want a “solution” isn’t how it works.
For RTSP cameras you can use the generic camera integration, which is done in the UI and supports unique_id. Otherwise open a feature request, or develop the required change and submit a PR.
