Hi all,
Does anyone know how i can use additional python libraries?
Using HassIO with AppDaemon and trying to import pycurl for example.
I get a message that this module is not available, but how can i add this??
Hi all,
You need to include it in the python_packages portion of the add-on config:
"log_level": "info",
"system_packages": [],
"python_packages": [
"pycurl"
Thanks for the quick response, looks like this is what i was searching for.
Tried to add the package but i guess it needs additional system packages.
[cont-init.d] 81-python-packages.sh: executing...
Collecting pycurl
Downloading https://files.pythonhosted.org/packages/e8/e4/0dbb8735407189f00b33d84122b9be52c790c7c3b25286826f4e1bdb7bde/pycurl-7.43.0.2.tar.gz (214kB)
Complete output from command python setup.py egg_info:
File "/tmp/pip-install-ogq2_2au/pycurl/setup.py", line 223, in configure_unix
stdout=subprocess.PIPE, stderr=subprocess.PIPE)
File "/usr/lib/python3.6/subprocess.py", line 709, in __init__
restore_signals, start_new_session)
File "/usr/lib/python3.6/subprocess.py", line 1344, in _execute_child
raise child_exception_type(errno_num, err_msg, err_filename)
FileNotFoundError: [Errno 2] No such file or directory: 'curl-config': 'curl-config'
File "<string>", line 1, in <module>
File "/tmp/pip-install-ogq2_2au/pycurl/setup.py", line 913, in <module>
ext = get_extension(sys.argv, split_extension_source=split_extension_source)
File "/tmp/pip-install-ogq2_2au/pycurl/setup.py", line 582, in get_extension
ext_config = ExtensionConfiguration(argv)
File "/tmp/pip-install-ogq2_2au/pycurl/setup.py", line 99, in __init__
self.configure()
File "/tmp/pip-install-ogq2_2au/pycurl/setup.py", line 227, in configure_unix
raise ConfigurationError(msg)
__main__.ConfigurationError: Could not run curl-config: [Errno 2] No such file or directory: 'curl-config': 'curl-config'
right, pycurl needs a lot of extra.
there where more attempts from people here on the forum, and it took them a while to figure out what all was needed.
Any solution to have my own package used instead ? Any way for instance to copy past the content of my site-package to the one fetch by AD ?
Hi there. Just been through this myself for a custom python app. The solution to pycurl is here Dahua IPC to MQTT App - #55 by xbmcnut
@xbmcnut
That was what i tried to acchieve, but i was missing the pycurl library inside the AppDaemon apps. I’ve searched for the packages needed and this is how i got it working:
"log_level": "debug",
"curl-dev",
"python3-dev",
"libressl-dev",
"musl-dev",
"gcc",
"libcurl"
"pycurl"
When it worked i started rewriting the application since i do not use mqtt, but just want to notify my devices including a snapshot
What my setup does is the following:
My previous setup was getting the snapshot from the camera directly, but sometimes the object was already gone so this was no option for me.
