Adding an Action to existing Blueprint?
I’m still a newbie with HA.
I’ve used successfully Blueprints. They work great.
I would like add a new action to a few Blueprints, like send me a notification to my phone or flash some light.
I’ve not been able to see how to do this?
Can you mod a Blueprint? I don’t want to mess them up.
TiA
You can always just make a new copy…
In the File editor of your choice navigate to config/blueprints, find the folder for the creator of the blueprint and copy/paste the file into your own folder (you can label it whatever you want) and modify it as you please. Once you’ve saved it, restart HA to make the new files load.
Easiest way i find is to turn the blueprint into an ordinary automation.
This you can do by opening a trace, and then copy the yaml under the ‘automation config’ tab and paste in into a new automation.
You now have the automation that you can adept as you see fit. :wink:
